Jerry Ye Wed, 09/09/2009 - 20:21
I am only able to locate HWIC-1FE and HWIC-4ESW.
For HWIC-1FE, you can only configure it as L3 port. You can look at the feature portion
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html
For HWIC-4ESW, you can configure L2 features.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b_ps5855_Products_Data_Sheet.html
HTH,
jerry
rechard_hk Wed, 09/09/2009 - 23:52
Dear Jerry,
Thank you for your link as above.
Could you more explain, i'm not clear for Wic-1FE and Wic-4ESW?
i just to know configure that :
1-for Wic-1FE:
interface FastEthernet0/0/0
description LAN
ip address 192.168.101.9 255.255.255.0
2-For Wic-4ESW:
interface Vlan1
description LAN
ip address 192.168.1.100 255.255.255.0
interface Vlan2
description LAN
ip address 192.168.2.200 255.255.255.0
could you let me know more than this?
Best Regards,
Rechard
Richard Burts Thu, 09/10/2009 - 04:46
Rechard
With the Wic-1FE you have another routed FastEthernet interface on the router. It functions just like the built in FastEthernet interfaces. (and it is not a switch port). With the 4ESW you actually have a 4 port Ethernet switch in the router. You can configure the ports as switch ports (including VLAN assignments and other switch functions) and you configure VLANs for the layer 3 interfaces.
The other obvious difference is that with Wic-1FE you have only 1 connection and with the 4ESW you have 4 connections.
Rick
Leo Laohoo Thu, 09/10/2009 - 14:42
Hi Rechard,
In the most simplest of terms, a HWIC-1FE, is like an extra router port to your router. The HWIC-4ESW is like putting a 4-port Layer 2 switch (2940/2950/2960) to your router just to increase (a little bit) the port capacity. You can purchase a PoE version of the HWIC-4ESW while you can't with a HWIC-1FE.
lruberintwari Tue, 06/26/2012 - 05:20
Hi ,
As mentioned by lolaohoo, is the HWIC-1FE has the same physical interface with WIC-1FE? I mean does both use the same connectivity cable? thanks to clarify.
Lionel
Sandeep Choudhary Tue, 06/26/2012 - 05:26
These are used ...only when you need more ports on router.Its depend on your requirement.
WIL-1FE---------configure as as L3
WIC-4ESW------configure as L2
You can use same cable.
HWIC-4ESW. It acts like a layer3 switch. You just configure ip addresses on the vlan interface. You can now use the physical port on the switch to be second outside.
HWIC-1FE/2FE is what we call Layer3 interface(routed interface).
Please rate if it helps.
oralsicool Mon, 07/01/2013 - 13:23
so, if I need limit Bandwidth on a LAN port with Cisco 1760, What Wic Must to use Wic-4esw, Wic-1enet or wic-1FE?
___
Tia
Orlando
Leo Laohoo Mon, 07/01/2013 - 15:52
I do not believe WIC-1FE is supported on a 1760 router.
If you want to limit the speed to a particular port, then you just do PBR.
oralsicool Mon, 07/01/2013 - 16:07
yor're right WIC-1FE ins not supported.
I Have Cisco 1760, WIC-1ADSL and 1 WIC slot available,
Bandwidch limit only is possible in router and L3 Switch.
I don't know if WIC-4ESW support PBR because is like a L2 switch. WIC-1ENET is L3 but only one RJ-45
Leo Laohoo Mon, 07/01/2013 - 16:14
If you want to limit the bandwidth to a particular user, here's a nasty way of doing things ...
Put the specific user in a specifc VLAN, of course you do inter-VLAN routing but with a 1760 router, you should be able to do this.
Apply the PBR on that specific VLAN.
