Please explaine, how it could be
Sep 9th, 2009
Hello.
I have lab question.
My topology is...
Router(2801)-trunk-switch(3560)-trunk-WLC
And some access ports on switch.
I have some vlans.
230- Managment
50 - UsersWifi
51-54 data(i don't have it on WLC)
I use tagging on all devices.
But! when a use
config interface vlan management 0.
I can ping managment interface only at wlan 50, but not in 230 or 51-54.
I missuderstand how WLC answer?
I use sniffer but still....
As i think - request for manamnent interface is from vlan 50, but how?
And i doen't use ProxyArp
dancampb Thu, 09/10/2009 - 05:01
  • Cisco Employee,
It sounds like you are having a native VLAN mismatch. Using a "0" for the VLAN identified for an interface on a controller sets that VLAN to be untagged. If you want the management interface to be untagged on the controller then make sure you have the same VLAN on the switch set to be native. In your case it looks like you would want to set VLAN 230 as the native VLAN on the trunk to the controller.
kudachkin Thu, 09/10/2009 - 23:28
Yes. When i have tag on WLC and native vlan on router. A cannot have ping between then. But i still can ping WLC managment from different vlan - that i have on WLC.
How?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
