One way Voice
Sep 10th, 2009
I am getting one way voice but only from calls where there has been a call forward has been set
antonio.vazquez Thu, 09/10/2009 - 02:37
have you revised if there is any firewall between the endpoint and tht CUCM? If there is a firewall between them it's possibly that it is blocking some ports.
If you found this post helpful, please rate it
AZaburdyayev Sun, 01/09/2011 - 07:12
You should check full ip path. How packed following. Ie in my case was similar problem.
My case was following :
             ISDN Pri                             h323
Cell GW --------------- Cisco GW(3725) ---------- Softswitch --- user
And between Cisco GW and Softswitch was router wich perfom nat for packets following to softswitch and I had problems.
In your case you should carefully check out connectivity and all network elements. Most often existing problem is firewall. Is it exists in your scheem ?
