Adding Pix device public interface through Proxy server into CSM Fails
Sep 10th, 2009
I am trying to add a device into CSM. The device is only reachable through proxy server. If i try to add the device, the connectivity test fails" unable to communicate with device". If i debug on the PIX i see no connection attemps. If imake a https connection from the Explorer from the windows server running CSM i get connected. I have set the proxy settings under Server Administration. I can update packages from CCO through the proxy. Is there somewhere else to tell CSM to run through proxy ?
