C6509-E and VS-S720-10G visio stencils
Sep 10th, 2009
Hi there,
I need those two stencils.
I have checked here http://www.cisco.com/en/US/prod/assets/visio/product_visio_icon0900aecd800fd93c.zip but:
- the one for the C6509-E is not there
- the one for the supervisor does not work properly (misaligned anchor points).
Thanks for helping...
andrecsthompson Tue, 04/30/2013 - 13:35
Also I am looking for the following stencils:
CEF720 16 port 10GE                    WS-X6816-10GE
CEF720 48 port 10/100/1000mb Ethernet  WS-X6848-GE-TX
The stencils above are very old
Greg Grimes Wed, 08/07/2013 - 09:03
Yes, the glue points for the VS-Sup720-10G are wrong and I can't figure out how to change them.  However, the VS-Sup720-10G-3C(&XL) has the glue points in the correct location.
andrecsthompson Wed, 08/07/2013 - 09:39
Hi Greg
Here are some tips:
1. Before selecting the Connector Tool, ensure the SUP-720 object is selected or you will be adding the points to nothing.
2. Try zooming in before adding the points, such as 400% or more.I go in as much as 800%
3. I would recommend using Visio 2013 or Visio 2010 but not earlier.
Hope this was helpful. I would like to hear your feedback on this.
