Cisco 2811 Dial up Internet Configuration Problem
Answered Question
Sep 10th, 2009
I have the following dial up problem please help me overcome this problem
i have configured Cisco 2811 to be used as a dial up router with one E1, so that subscriber can dial in and use the internet.
the problem is that when adding "interface Group-Async1" the command (group-range 1 30) when i excute this command it indicates accepting the command but when i show config, i am still getting (group-range 1 1.
below is the show ver result.
STEL#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(21a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 29-Sep-08 16:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
STEL.Hargeisa uptime is 3 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-21a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.50) with 247808K/14336K bytes of memory.
Processor board ID FHK1204F3UT
2 FastEthernet interfaces
31 Serial interfaces
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
63808K bytes of ATA CompactFlash (Read/Write)
Hassan R.
Correct Answer by paolo bevilacqua about 7 years 8 months ago
Both of them.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sat, 09/12/2009 - 02:01
  • Hall of Fame,
    Founding Member
You're welcome, please remember to rate useful posts with the scrollbox below.
hirmoge123_2 Sun, 09/13/2009 - 20:37
Do I need both cards or one of them:
PVDM2-36DM and HWIC-1CE1T1-PR
Correct Answer
paolo bevilacqua Mon, 09/14/2009 - 03:46
  • Hall of Fame,
    Founding Member
Both of them.
