One Way Voice on ISDN E1 - Debug isdn q931
nwkotze
Kindly provide me with possible solutions:
When dialing 144 we get one Way Voice, They can no hear us, we can hear them.
When dialing 164 no problems...
BAD call - one way Voice:
Aug 25 19:53:56.733: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x4 0x1, Calling num 7774400
Aug 25 19:53:56.737: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 144
Aug 25 19:53:56.737: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x05D5
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Originat
Session address is non-ISDN
Calling Party Number i = 0x4181, '7774400'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0x81, '144'
Plan:ISDN, Type:Unknown
Aug 25 19:53:57.065: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x85D5
Aug 25 19:54:01.005: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x85D5
*********note no call connect message*****
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Progress Ind i = 0x8A88 - In-band info or appropriate now available
Aug 25 19:54:18.284: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x05D5
Cause i = 0x8090 - Normal call clearing
Aug 25 19:54:18.408: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x85D5
Aug 25 19:54:18.412: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x05D5
2811-GW1#
good call
Aug 25 19:55:17.401: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num 7774400
Aug 25 19:55:17.405: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 164
Aug 25 19:55:17.405: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x05D6
Standard = CCITT
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0x81, '164'
Aug 25 19:55:17.733: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x85D6
Aug 25 19:55:20.581: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x85D6
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band info
Aug 25 19:55:21.541: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x85D6
Date/Time i = 0x0908191537
Date (yr-mm-dd) = 09-08-25
Time (hr:mnt:sec) = 21:55:76
Connected Number i = 'A', 0x83, '6800000'
Aug 25 19:55:21.545: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected
to 164 N/A
Aug 25 19:55:21.545: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref =0
x05D6
Aug 25 19:55:27.558: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected
to 164 N/A
Aug 25 19:55:36.298: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30 disconnected
from 164 , call lasted 14 seconds
Aug 25 19:55:36.302: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x05D6
Aug 25 19:55:36.442: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x85D6
Aug 25 19:55:36.446: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x05D6
2811-GW1#
Thank you for your Time!!
Many Thanks,
Nico
paolo bevilacqua
Yes this happens because no connect mesxsage is received.
Where is the call going, CME, CME are you using MGCP or H.323 ?
