WLC 5508 SFP Unsupported
Sep 10th, 2009
I plugged in SFP modules in the WLC ports and the port status (Controller -> Ports) shows SFP Type as Unsupported. The modules I tried are GLC-SX-MM and GLC-LH-SM; neither of which work, link is down down. Any ideas?
Overall Rating: 5 (1 ratings)
Lucien Avramov Thu, 09/10/2009 - 16:50
You need to use : GLC-T= (part number) which is: 1000BASE-T SFP
BTW, Controller ports are 1000BaseT and will connect ONLY
Gigabit ethernet ports on the switch and not to Fast ethernet ports.
Leo Laohoo Thu, 09/10/2009 - 17:00
Hi Lucien,
Doesn't make any sense. Are you saying that the 5508 will only support GLC-T?
According to the Data Sheet, "Small Form-Factor Pluggable (SFP) options (only Cisco SFPs supported): GLC-T, GLC-SX-MM, GLC-LH-SM".
Lucien Avramov Thu, 09/10/2009 - 23:58
I have tested the one I quoted and recommend to use it.
I have not tried the other SFP and quite frankly have not seen them in use with WLC that much in the field.
The SFP can be damaged, make sure they work in other devices properly, those are very sensitive.
The other possibility is that you may be hitting a software bug I will look and post if i find any. For that I need to know what model of WLC and what version you are using.
THanks for posting that it doesnt make any sense.
What tells you that the device in use is a 5508?
Leo Laohoo Sat, 09/12/2009 - 18:23
Hi Lucien,
Thanks for the quick response. According to the title of the post the user is using a 5508 (and most likely the new 6.0 firmware).
Frankly, I have no idea why the 4400 and the 5500 were designed with SFP-only slots. I would've thought that it would be designed with "dual-personality" ports.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
