How tell the port type
dan_track
I've got a switch with gig copper ports, 10gig ports, 1gig fibre ports etc...
After running a show int how can I tell which of these port types the following output is:
sh int gi 4/1
GigabitEthernet4/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 001e.be36.2bd0 (bia 001e.be36.2bd0)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 3/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:11, output 00:00:57, output hang never
Last clearing of "show interface" counters 4d09h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 566
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 7957000 bits/sec, 4725 packets/sec
5 minute output rate 11801000 bits/sec, 7778 packets/sec
1014391352 packets input, 600569983360 bytes, 0 no buffer
Received 84895844 broadcasts (84580514 multicasts)
0 watchdog, 0 multicast, 0 pause input
1291693362 packets output, 676070256873 bytes, 0 underruns
Dan
ktwaddell
Hi Dan
Do the following command
sh int status
and that will show you want you need
Kev
