Lost control of Integrated-Service-Engine (WLCM)
Sep 10th, 2009
How do I regain communication with WLCM in a 2821?
I was trying to get this running and had gone through the wizard for the basic config and could session to the controller before discovering the IP addressing I used was in the wrong MPLS VRF. I did a clear config and reset system, save: no.
Even putting the IP I originally used back on int in1/0 I cannot session to the controller module.
router-mpls#service-module Integrated-Service-Engine 1/0 session
Trying **.*.*.***, 2066 ...
% Connection refused by remote host
I have not reloaded the 2821 except that is did crash & reload on its own during this. A scheduled reload will take a figurative act of congress to approve.
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
router-mpls uptime is 1 day, 18 hours, 18 minutes
System returned to ROM by error - an Illegal Opcode exception, PC 0x8CA1E1AC at 15:13:30 MDT Tue Sep 8 2009
System restarted at 15:15:50 MDT Tue Sep 8 2009
System image file is "flash:/c2800nm-advipservicesk9-mz.124-22.T.bin"
Any suggestions?
Router:
Cisco 2821 (revision 53.51) with 1028096K/20480K bytes of memory.
Processor board ID ***********
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Integrated Service Engine(s)
Cisco WLAN Controller 4.2.61.0 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Thanks!
khushal05 Sun, 06/13/2010 - 09:42
Experiencing the same issues on UC500 after Power Outtage -
Have done reset, Powerdown - and also will not allow software upgrade either.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
