877 ADSL2+
Answered Question
Sep 10th, 2009
Hi all,
My 877 routers dsl mode is set to ADSL2+ and a sh dsl int atm0 displays 2 downstream channels and 2 upstream rather than the usual Fast and Interleave that i'm used to. Can anyone tell me the difference between the two channels and if there is any differences between adsl2+ showing channels only and dsl that shows fast and interleaving.
Thanks guys!
Correct Answer by Paolo Bevilacqua about 7 years 5 months ago
ADSL2+ can use alternative/overlapping bands depending by detected cross-talk from adjacent pairs in the binder. The details are contained in the official standard but require specialized knowledge to be fully understood.
In your case the router is simply indicating which band(s) are being used and everything appears OK.
Overall Rating: 5 (1 ratings)
petenixon Thu, 09/10/2009 - 07:18
here is the output of the sh command
edit: also i don't mean the difference between upstream and downstream!! the difference between channel 0 and channel 1.
thanks
Correct Answer
Paolo Bevilacqua Thu, 09/10/2009 - 08:27
