VPN issue
Sep 10th, 2009
we have using PIX 515E and connected a site to site vpn between headoffice and branch office
In our PIX we used three interface
O/S - X.X.80.5
I/S - 10.195.21.X -------Vlan 5 in core switch
I/S 2 - 10.195.1.X ------vlan 6 in core switch
the VPN are working between I/S 2 and remote office but when i ping 10.195.21.X its not pinging
interface Ethernet1
nameif inside
security-level 100
ip address 10.195.21.X
interface Ethernet2
nameif inside2
security-level 80
ip address 10.195.1.X
the config is
access-list 101 extended permit ip
access-list 124 extended permit ip
global (outside) 1 interface
nat (inside) 1
nat (inside2) 0 access-list 101
nat (inside2) 1
whether it will work if i add no nat for inside also
or need to some ACL to allow remote network to access inside network
acomiskey Thu, 09/10/2009 - 08:50
Looks like you also need a nat 0 for inside.
access-list 102 extended permit
nat (inside) 0 access-list 102
then fix the net and mask for your other acl...
vinoth.kumar Thu, 09/10/2009 - 09:13
can i use the same access-list 101 for inside also
like nat (inside) 0 access-list 101
is any problem using this
acomiskey Thu, 09/10/2009 - 09:17
Like this?
Yes you can, it should work that way, but it is better to separate them in my opinion.
