Upgrade CCM 4.2.X to 6.1.X
Sep 10th, 2009
I juste want a confirmation about upgrade of callmanager from 4.2 to 6.1 in mixed security mode.
Don't we must delete the CTL files on phones after the upgrade of CCM ?
I have got the follow informations from DMA :
[08:29:58 PM] Beginning CAPF export from
[08:29:58 PM] Exporting CAPF data.
[08:29:58 PM] CAPF data exported successfully.
[08:29:58 PM] CAPF data export is complete.
[08:29:58 PM]
[08:29:58 PM] Beginning CTL export from
[08:29:58 PM] Exporting CTL data.
[08:29:58 PM] CTL data exported successfully.
[08:29:58 PM] CTL data export is complete.
Thank you for your answer.
Best regards.
gogasca Sun, 09/13/2009 - 17:13
you need to re-run the ctl client to update CTL file.
IP Phone should be able to update CTL file after that/
DWAM_2 Mon, 09/21/2009 - 01:58
little feedback :
We had the migration this week end.
After the re-run of CTL client, it works good.
No need to pass physically on all phone, but we have to open new port on Firewall.
Thank you for your help.
