Voicemail rings fast busy if one person is in it.
Sep 10th, 2009
First time I have seen this kind of situation.  This is on a 32U UC520, if anyone is in the voicemail system, the next person will receive fast busy, this happens both for callers being transferred and for internal users accessing voicemail.  I'm not even sure where to start.  I'm using cca 2.0.1 with the latets softpaks..
Marcos Hernandez Thu, 09/10/2009 - 09:44
  • Blue, 1500 points or more
This should not happen. Our voicemail module (CUE) can accommodate up to six audio sessions (AA + VM). Does this ALWAYS happen? Or only when there are calls throug the AA?
Marcos
chris unger Thu, 09/10/2009 - 10:26
there is no AA.
UC with PRI
main number rings to blast group->busy/na->goes to group voicemail.  Other numbers translate to DIDs.  the only symptom I see is that at any given moment a user can press their 'message' button and it rings fast busy.  The phones are 7960s.  When I get back onsite I will contact TAC.
chris unger Tue, 09/15/2009 - 13:22
very strange indeed...  So I went to the Cisco Unity web gui, and found the problem.  I'm using 3 digit extensions, but under the VM config, it has 2097 as the VM port number with 6 max and also has 297 as the VM port with only 1 max...
Related Content
