Downgrade WLC software
Sep 10th, 2009
Is it safe to downgrade WLC 4402 software from 6 to 5.1? My problm is the web autentication through IAS server dosn't work - can't pass the authentication login window,it works before on 5.1
Thanks.
Leo Laohoo Thu, 09/10/2009 - 15:52
I don't know about "safe" but there's a risk that you may/might loose your config after the downgrade. Take a copy of your config.
Lucien Avramov Thu, 09/10/2009 - 16:27
also controller 6.0 runs CAPWAP and 5.1, LWAPP, so you will have a downtime for your APs and it sounds like it will have to change the code on the APs as well. Sounds taking quite some risks here.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
