Cisco Configuration assisstant
wfares
i have cisco wireless controller 526 with access point 521 every thing work great but when i use cisco configuration assisstant software i can't view the access point in the toplogy view i only see the controller and the switch
Steven DiStefano
You should see the APs with little circles in the ICON on the topology if in Standalone mode, or Triangles if in LWAPP mode.
This is of course provided they are plugged into the Ethernet POE Switchport on the UC500.
CCA allows you to convert from Standalone to LWAPP mode as well.
Check this out:
https://www.myciscocommunity.com/docs/DOC-6679
Steve
