1131 AP's flashing orange/amber
Starthorn
What does it mean when your 1131 access points are flashing orange or amber.
Its not showing up on my 4404 controllers. I think its a bad run from the wireing closet to the ap.
dancampb
Level 7
Level 7
It depends on which LED you are referring to. Here is a chart of what the different LED's mean.
http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c4.html#wp1030793
I mean the Status LED. The circle on top. I've seen the red color on the AP's before so I know its not that. I don't see anything on the chart for flashing amber.
That's what he meant. It's also known as the "mood ring".
During bootup, the mood ring will flash in a slow succession. It will flash all the colors, red, orange, purple, blue, green ...
During it's search for a WLC, the color is mostly red/orange/amber.
When it's found a controller, the color is green.
When someone or something has joined to it the color is blue/purple.
If the controller is flashing all the colors in a quick succession then the AP's probably in ROMMON.
