Bat Update Users
Sep 10th, 2009
(CCM 6.1.3190)
I am running a bulk update on users to associate their primary line all OK. However the users come from a sync from the customers AD. Some times the user doesn't exist and you get an error from the Job scheduler, this is OK. What it doesn't do though is tell you which user device profile you are trying to associate to an end user failed.
It just says 2020 user doesn't exist. Why / How can I find out which UDP has failed.
Any Ideas ?
Steve
smalkeric Wed, 09/16/2009 - 05:53
What is the exact version of BAT you are using? What version of CM are you running including SR or ES? How many servers (Pub and Sub) do you have in the cluster?
steve.dyer Thu, 09/17/2009 - 06:15
CCM is System version: 6.1.3.3190-1
Bat is bat_6[1].1.3.3190(1).xlt
There is 1 Pub and 3 subs.
Steve
