3560 and 3750 switches
Answered Question
Sep 10th, 2009
I have a list of switches in the same family that I must test for different clients, now I need to know if my decision is not dangerous. below is the list of these boxes:
WS-C3560-24PS-S
WS-C3560-48PS-E
WS-C3560-48PS-S
WS-C3560G-48PS-S
WS-C3750-24PS-E
WS-C3750-48PS-E
WS-C3750-48TS-E
WS-C3750-48TS-S
WS-C3750G-24PS-S
WS-C3750G-24TS-E1U
WS-C3750G-48PS-S
WS-C3750G-48TS-S
I want to test only one box per family (3500 and 3700) using the recent IOS and approve that IOS on all these boxes, my believe is the functionalities are the same the only diference is the additional ports, forwarding rate and the number of SFP's. am I right?
Correct Answer by Lucien Avramov about 7 years 9 months ago
Different catOS images. The code is a .bin file hence binaries.
Correct Answer by Joseph W. Doherty about 7 years 9 months ago
If your testing features of an IOS, platforms that run the same binary should support the same functions.
Although the 3560 and 3750 run "different" binaries, I believe they, more or less, are the same device except for the Stackwise provided on the latter. (Doubt there would be much need to test both platforms.)
Correct Answer by Leo Laohoo about 7 years 9 months ago
Don't forget the stacking capability.
Correct Answer by Jon Marshall about 7 years 9 months ago
Mpho
Your approach of only testing one box per family should be fine. There is certainly no need to test each box in a family. Perhaps the only thing i might do is to test a PoE and non-PoE switch per family.
Jon
Overall Rating: 5 (4 ratings)
Correct Answer
Jon Marshall Thu, 09/10/2009 - 13:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mpho
Jon
Correct Answer
Leo Laohoo Thu, 09/10/2009 - 14:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Correct Answer
Joseph W. Doherty Thu, 09/10/2009 - 17:20
mailaglady2 Thu, 09/10/2009 - 23:00
Hi Joseph
What do you mean by "same and different binaries" firts time hearing that?
Regrads
Mpho
Correct Answer
Lucien Avramov Fri, 09/11/2009 - 00:42
  • Red, 2250 points or more
srue Tue, 09/15/2009 - 05:40
  • Blue, 1500 points or more
some of the model numbers you list included the IP base image (xxx-S), other models include IP services (xxx-E). Keep that in mind in your reviews and testing.
mailaglady2 Tue, 09/15/2009 - 05:46
Does it mean every switch that ends with an xxx-S it means that switch is running ip base image then xxx-E ip services, Always?
srue Tue, 09/15/2009 - 06:04
Yes. Unless the image has been changed from IP Base to IP Services (or the other way around).
The hardware is the same, it's the IOS (and license) that is different only.
