BGP and Weight
mehrdad
Level 3
Level 3
I have a question about BGP and Weight
If we have two uplinks and learn the below routes (uplink1 has weight 100 and uplink2 has weight 50)
192.168.0.0/20 uplink1 weight 100
192.168.1.0/24 uplink2 weight 50
which uplink will be best for destination 192.168.1.10? I know the higher weight is preferred but how bout smaller subnet in this scenario?
Mehrdad
Edison Ortiz
Uplink2 will be preferred for destination 192.168.1.10 - it has the longest mask.
__
Edison.
Thank you for your prompt reply.
any solution to force traffic to go uplink1? it means WEIGHT has higher preferences than longest mask
Choices are:
1) Have Link1 send you a /24
2) Have Link2 send you a /20 instead of /24
3) Filter routes from Link2
In order to perform BGP traffic engineering, routes must be the same and a /24 via one link vs a /20 via another link aren't the same.
