Problem with auto-answer with 7941 on UC500
Sep 10th, 2009
We have a client with a UC500 on 7.0.2 (20T) package that started having an issue with one of their 7941 phones...  here is the issue.
They have a main line number that is overlayed onto the second button on the phone, here is the phone on the config:
ephone  13
device-security-mode none
mac-address xxxx.xxxx.xxxx
type 7941
button  1:11 2c2,3,21
When the mainline number is called and they try and answer, it does not auto-answer, they have to press the second button to answer.   We replaced this phone with another 7941 and it started working again even after a bunch of trial attempts, so we thought all was well.   About a week later, the phone started doing this again and not auto-answering.
What could be the issue with this happening again?  Keep in mind that another 7941 setup the exact same way has not had any problems and still auto-answers the main line.
Thanks!
Steven Smith Thu, 09/10/2009 - 14:33
  • Gold, 750 points or more
Could you post the entire config?  Please remove passwords.
brandon.kallas Thu, 09/10/2009 - 15:06
version 12.4
parser config cache interface
no service pad
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname Jenos
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-20.T2
boot-end-marker
logging message-counter syslog
logging buffered 1000000
no logging console
enable secret 5
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone MST -7
clock summer-time PST recurring
crypto pki trustpoint TP-self-signed-1356120334
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1356120334
revocation-check none
rsakeypair TP-self-signed-1356120334
crypto pki certificate chain TP-self-signed-1356120334
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31333536 31323033 3334301E 170D3039 30393034 31333339
  31395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33353631
  32303333 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D11E D6336A90 480535D7 DB1B939C A2307739 A9B2D079 FF421266 EE31DF0D
  7DD31309 B9B5FFFD 2D265D45 66822573 7D0EC42E 20D50910 7818AD49 138C26F9
  3419B062 A5EFE9C5 4B6EA6C6 103CEDE9 6F7E1D9B 5636741C 5265F92E CF310CEB
  581F3A07 355B3F46 3F8B5E27 C584D15C 02D82013 D4C04554 28D1FE29 EBDAB077
  CA8B0203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
  551D1104 09300782 05554335 3230301F 0603551D 23041830 168014E8 CE2F5B92
  9E877EC4 E45D18EB BEA1A3AF EDFFA630 1D060355 1D0E0416 0414E8CE 2F5B929E
  877EC4E4 5D18EBBE A1A3AFED FFA6300D 06092A86 4886F70D 01010405 00038181
  00A0436F 0AAAF416 9078787D E7B514D2 0C752865 64A94194 7312EA48 4BBAFA65
  365FF811 FA6D5171 2C27D474 85ACE400 10C85237 13928DEB B9FBB217 160C8176
  94299FF0 57E9A3A0 71BBF484 B99E09B1 9B4F6499 0B7A5DE6 ED013836 446B4404
  E7F2E7AB 77F2D69F C605D46C C0D2CFE5 286443BD 92147D08 5586C9BB C3464B1E 39
  quit
dot11 syslog
dot11 ssid uc520-data
   vlan 1
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 0256550A52565C716D1B5D485D47455A2D577F7F77
dot11 ssid uc520-voice
   vlan 100
   authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server***.***.***.*** ***.***.***.***
ip name-server ***.***.***.***
ip name-server ***.***.***.***1
ip inspect log drop-pkt
ip inspect name SDM_MEDIUM appfw SDM_MEDIUM
ip inspect name SDM_MEDIUM cuseeme
ip inspect name SDM_MEDIUM dns
ip inspect name SDM_MEDIUM ftp
ip inspect name SDM_MEDIUM h323
ip inspect name SDM_MEDIUM https
ip inspect name SDM_MEDIUM icmp
ip inspect name SDM_MEDIUM imap reset
ip inspect name SDM_MEDIUM pop3 reset
ip inspect name SDM_MEDIUM netshow
ip inspect name SDM_MEDIUM rcmd
ip inspect name SDM_MEDIUM realaudio
ip inspect name SDM_MEDIUM rtsp
ip inspect name SDM_MEDIUM esmtp
ip inspect name SDM_MEDIUM sqlnet
ip inspect name SDM_MEDIUM streamworks
ip inspect name SDM_MEDIUM tftp
ip inspect name SDM_MEDIUM tcp
ip inspect name SDM_MEDIUM udp
ip inspect name SDM_MEDIUM vdolive
appfw policy-name SDM_MEDIUM
  application im aol
    service default action allow alarm
    service text-chat action allow alarm
    server permit name login.oscar.aol.com
    server permit name toc.oscar.aol.com
    server permit name oam-d09a.blue.aol.com
    audit-trail on
  application im msn
    server permit name messenger.hotmail.com
    server permit name gateway.messenger.hotmail.com
    server permit name webmessenger.msn.com
    audit-trail on
  application http
    strict-http action allow alarm
    port-misuse im action reset alarm
    port-misuse p2p action reset alarm
    port-misuse tunneling action allow alarm
  application im yahoo
    server permit name scs.msg.yahoo.com
    server permit name scsa.msg.yahoo.com
    server permit name scsb.msg.yahoo.com
    server permit name scsc.msg.yahoo.com
    server permit name scsd.msg.yahoo.com
    server permit name cs16.msg.dcn.yahoo.com
    server permit name cs19.msg.dcn.yahoo.com
    server permit name cs42.msg.dcn.yahoo.com
    server permit name cs53.msg.dcn.yahoo.com
    server permit name cs54.msg.dcn.yahoo.com
    server permit name ads1.vip.scd.yahoo.com
    server permit name radio1.launch.vip.dal.yahoo.com
    server permit name in1.msg.vip.re2.yahoo.com
    server permit name data1.my.vip.sc5.yahoo.com
    server permit name address1.pim.vip.mud.yahoo.com
    server permit name edit.messenger.yahoo.com
    server permit name messenger.yahoo.com
    server permit name http.pager.yahoo.com
    server permit name privacy.yahoo.com
    server permit name csa.yahoo.com
    server permit name csb.yahoo.com
    server permit name csc.yahoo.com
    audit-trail on
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
max-dn 56
max-pool 14
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice-card 0
no dspfarm
username ***** privilege 15 secret 5
username ***** privilege 15 password 7
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key
pool EZVPN_POOL_1
acl 105
max-users 10
crypto ipsec transform-set ESP_AES_SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP_3DES_SHA esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP_AES_SHA ESP_3DES_SHA
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
archive
log config
  logging enable
  logging size 600
  hidekeys
process-max-time 50
ip tftp source-interface Loopback0
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
policy-map sdmappfwp2p_SDM_MEDIUM
class sdm_p2p_gnutella
class sdm_p2p_bittorrent
class sdm_p2p_edonkey
class sdm_p2p_kazaa
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address **.**.**.** 255.255.255.252
ip access-group 104 in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_MEDIUM out
duplex auto
speed auto
snmp trap ip verify drop-rate
service-policy input sdmappfwp2p_SDM_MEDIUM
service-policy output sdmappfwp2p_SDM_MEDIUM
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group$FW_INSIDE$
ip unnumbered Loopback0
ip access-group 100 in
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport mode trunk
macro description cisco-wireless
spanning-tree portfast
interface FastEthernet0/1/1
switchport voice vlan 100
macro description cisco-phone
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
encryption vlan 100 key 1 size 128bit 7 834DADCC7EDA066F07CF67AB7639 transmit-key
encryption vlan 100 mode wep mandatory
encryption vlan 1 mode ciphers tkip
ssid uc520-data
ssid uc520-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip local pool EZVPN_POOL_1 192.168.11.100 192.168.11.200
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ***.***.***.***
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
access-list 100 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 10.1.1.0 0.0.0.255 any
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip ***.***.***.*** 0.0.0.3 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip ***.***.***.*** 0.0.0.3 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip ***.***.***.*** 0.0.0.3 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip ***.***.***.*** 0.0.0.3 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_424##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit ahp any host 67.51.148.230
access-list 104 permit esp any host 67.51.148.230
access-list 104 permit udp any host 67.51.148.230 eq isakmp
access-list 104 permit udp any host 67.51.148.230 eq non500-isakmp
access-list 104 permit ip host 192.168.11.200 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.199 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.198 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.197 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.196 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.195 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.194 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.193 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.192 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.191 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.190 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.189 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.188 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.187 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.186 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.185 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.184 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.183 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.182 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.181 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.180 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.179 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.178 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.177 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.176 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.175 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.174 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.173 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.172 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.171 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.170 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.169 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.168 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.167 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.166 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.165 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.164 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.163 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.162 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.161 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.160 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.159 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.158 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.157 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.156 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.155 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.154 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.153 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.152 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.151 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.150 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.149 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.148 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.147 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.146 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.145 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.144 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.143 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.142 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.141 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.140 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.139 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.138 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.137 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.136 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.135 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.134 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.133 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.132 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.131 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.130 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.129 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.128 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.127 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.126 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.125 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.124 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.123 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.122 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.121 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.120 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.119 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.118 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.117 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.116 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.115 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.114 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.113 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.112 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.111 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.110 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.109 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.108 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.107 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.106 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.105 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.104 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.103 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.102 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.101 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.100 192.168.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.200 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.199 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.198 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.197 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.196 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.195 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.194 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.193 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.192 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.191 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.190 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.189 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.188 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.187 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.186 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.185 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.184 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.183 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.182 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.181 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.180 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.179 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.178 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.177 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.176 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.175 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.174 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.173 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.172 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.171 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.170 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.169 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.168 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.167 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.166 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.165 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.164 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.163 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.162 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.161 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.160 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.159 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.158 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.157 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.156 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.155 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.154 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.153 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.152 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.151 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.150 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.149 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.148 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.147 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.146 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.145 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.144 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.143 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.142 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.141 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.140 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.139 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.138 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.137 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.136 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.135 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.134 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.133 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.132 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.131 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.130 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.129 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.128 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.127 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.126 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.125 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.124 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.123 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.122 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.121 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.120 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.119 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.118 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.117 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.116 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.115 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.114 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.113 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.112 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.111 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.110 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.109 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.108 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.107 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.106 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.105 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.104 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.103 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.102 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.101 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.100 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.11.200 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.199 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.198 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.197 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.196 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.195 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.194 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.193 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.192 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.191 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.190 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.189 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.188 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.187 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.186 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.185 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.184 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.183 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.182 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.181 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.180 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.179 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.178 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.177 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.176 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.175 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.174 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.173 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.172 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.171 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.170 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.169 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.168 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.167 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.166 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.165 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.164 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.163 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.162 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.161 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.160 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.159 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.158 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.157 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.156 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.155 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.154 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.153 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.152 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.151 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.150 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.149 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.148 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.147 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.146 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.145 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.144 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.143 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.142 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.141 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.140 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.139 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.138 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.137 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.136 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.135 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.134 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.133 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.132 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.131 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.130 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.129 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.128 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.127 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.126 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.125 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.124 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.123 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.122 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.121 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.120 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.119 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.118 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.117 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.116 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.115 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.114 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.113 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.112 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.111 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.110 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.109 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.108 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.107 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.106 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.105 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.104 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.103 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.102 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.101 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.100 10.1.1.0 0.0.0.255
access-list 104 permit ip host 192.168.11.200 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.199 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.198 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.197 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.196 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.195 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.194 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.193 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.192 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.191 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.190 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.189 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.188 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.187 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.186 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.185 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.184 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.183 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.182 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.181 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.180 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.179 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.178 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.177 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.176 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.175 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.174 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.173 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.172 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.171 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.170 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.169 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.168 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.167 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.166 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.165 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.164 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.163 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.162 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.161 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.160 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.159 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.158 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.157 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.156 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.155 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.154 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.153 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.152 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.151 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.150 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.149 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.148 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.147 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.146 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.145 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.144 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.143 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.142 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.141 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.140 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.139 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.138 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.137 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.136 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.135 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.134 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.133 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.132 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.131 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.130 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.129 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.128 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.127 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.126 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.125 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.124 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.123 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.122 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.121 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.120 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.119 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.118 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.117 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.116 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.115 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.114 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.113 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.112 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.111 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.110 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.109 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.108 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.107 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.106 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.105 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.104 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.103 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.102 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.101 10.1.10.0 0.0.0.255
access-list 104 permit ip host 192.168.11.100 10.1.10.0 0.0.0.255
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 permit udp host ***.***.***.*** eq domain any
access-list 104 permit icmp any host ***.***.***.*** echo-reply
access-list 104 permit icmp any host ***.***.***.*** time-exceeded
access-list 104 permit icmp any host ***.***.***.*** unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any log
access-list 105 remark EZVPN_ACL_1
access-list 105 remark SDM_ACL Category=4
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
access-list 105 permit ip 192.168.11.0 0.0.0.255 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 10.1.10.0 0.0.0.255 any
access-list 106 remark SDM_ACL Category=2
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.100
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.101
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.102
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.103
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.104
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.105
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.106
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.107
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.108
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.109
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.110
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.111
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.112
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.113
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.114
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.115
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.116
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.117
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.118
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.119
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.120
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.121
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.122
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.123
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.124
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.125
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.126
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.127
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.128
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.129
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.130
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.131
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.132
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.133
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.134
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.135
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.136
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.137
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.138
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.139
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.140
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.141
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.142
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.143
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.144
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.145
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.146
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.147
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.148
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.149
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.150
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.151
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.152
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.153
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.154
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.155
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.156
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.157
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.158
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.159
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.160
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.161
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.162
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.163
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.164
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.165
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.166
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.167
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.168
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.169
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.170
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.171
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.172
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.173
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.174
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.175
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.176
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.177
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.178
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.179
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.180
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.181
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.182
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.183
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.184
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.185
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.186
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.187
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.188
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.189
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.190
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.191
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.192
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.193
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.194
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.195
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.196
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.197
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.198
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.199
access-list 106 deny   ip 10.1.10.0 0.0.0.255 host 192.168.11.200
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.100
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.101
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.102
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.103
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.104
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.105
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.106
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.107
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.108
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.109
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.110
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.111
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.112
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.113
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.114
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.115
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.116
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.117
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.118
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.119
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.120
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.121
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.122
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.123
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.124
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.125
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.126
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.127
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.128
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.129
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.130
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.131
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.132
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.133
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.134
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.135
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.136
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.137
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.138
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.139
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.140
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.141
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.142
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.143
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.144
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.145
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.146
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.147
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.148
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.149
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.150
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.151
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.152
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.153
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.154
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.155
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.156
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.157
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.158
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.159
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.160
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.161
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.162
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.163
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.164
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.165
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.166
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.167
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.168
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.169
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.170
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.171
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.172
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.173
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.174
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.175
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.176
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.177
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.178
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.179
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.180
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.181
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.182
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.183
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.184
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.185
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.186
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.187
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.188
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.189
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.190
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.191
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.192
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.193
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.194
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.195
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.196
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.197
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.198
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.199
access-list 106 deny   ip 10.1.1.0 0.0.0.255 host 192.168.11.200
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.100
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.101
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.102
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.103
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.104
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.105
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.106
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.107
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.108
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.109
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.110
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.111
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.112
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.113
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.114
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.115
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.116
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.117
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.118
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.119
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.120
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.121
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.122
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.123
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.124
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.125
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.126
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.127
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.128
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.129
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.130
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.131
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.132
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.133
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.134
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.135
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.136
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.137
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.138
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.139
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.140
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.141
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.142
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.143
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.144
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.145
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.146
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.147
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.148
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.149
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.150
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.151
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.152
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.153
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.154
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.155
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.156
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.157
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.158
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.159
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.160
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.161
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.162
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.163
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.164
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.165
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.166
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.167
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.168
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.169
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.170
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.171
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.172
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.173
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.174
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.175
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.176
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.177
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.178
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.179
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.180
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.181
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.182
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.183
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.184
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.185
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.186
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.187
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.188
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.189
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.190
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.191
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.192
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.193
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.194
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.195
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.196
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.197
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.198
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.199
access-list 106 deny   ip 192.168.11.0 0.0.0.255 host 192.168.11.200
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.100
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.101
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.102
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.103
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.104
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.105
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.106
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.107
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.108
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.109
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.110
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.111
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.112
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.113
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.114
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.115
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.116
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.117
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.118
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.119
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.120
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.121
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.122
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.123
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.124
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.125
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.126
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.127
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.128
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.129
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.130
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.131
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.132
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.133
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.134
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.135
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.136
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.137
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.138
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.139
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.140
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.141
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.142
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.143
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.144
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.145
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.146
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.147
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.148
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.149
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.150
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.151
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.152
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.153
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.154
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.155
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.156
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.157
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.158
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.159
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.160
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.161
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.162
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.163
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.164
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.165
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.166
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.167
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.168
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.169
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.170
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.171
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.172
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.173
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.174
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.175
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.176
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.177
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.178
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.179
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.180
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.181
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.182
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.183
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.184
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.185
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.186
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.187
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.188
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.189
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.190
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.191
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.192
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.193
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.194
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.195
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.196
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.197
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.198
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.199
access-list 106 deny   ip 192.168.10.0 0.0.0.255 host 192.168.11.200
access-list 106 permit ip 10.1.10.0 0.0.0.3 any
access-list 106 permit ip 192.168.10.0 0.0.0.255 any
access-list 106 permit ip 10.1.1.0 0.0.0.255 any
snmp-server community RO
route-map SDM_RMAP_1 permit 1
match ip address 106
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:SIP3951.8-0-2-0.zz
tftp-server flash:/phones/3951/BOOT3951.0-0-0-9.zz alias BOOT3951.0-0-0-9.zz
tftp-server flash:/phones/3951/DSP3951.0-0-0-2.zz alias DSP3951.0-0-0-2.zz
tftp-server flash:/phones/3951/SIP3951.8-1-2-0.zz alias SIP3951.8-1-2-0.zz
tftp-server flash:/phones/7906_7911/cnu11.8-3-4-16.sbn alias cnu11.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/apps11.8-3-4-16.sbn alias apps11.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-3-4-16.sbn alias jar11sccp.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-3-5S.loads alias SCCP11.8-3-5S.loads
tftp-server flash:/phones/7906_7911/cvm11sccp.8-3-4-16.sbn alias cvm11sccp.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-3-4-16.sbn alias dsp11.8-3-4-16.sbn
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7970_7971/dsp70.8-3-4-16.sbn alias dsp70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-3-4-16.sbn alias cnu70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7970_7971/SCCP70.8-3-5S.loads alias SCCP70.8-3-5S.loads
tftp-server flash:/phones/7970_7971/apps70.8-3-4-16.sbn alias apps70.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/jar70sccp.8-3-4-16.sbn alias jar70sccp.8-3-4-16.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-3-4-16.sbn alias cvm70sccp.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-3-4-16.sbn alias dsp41.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-3-5S.loads alias SCCP41.8-3-5S.loads
tftp-server flash:/phones/7941_7961/cnu41.8-3-4-16.sbn alias cnu41.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-3-4-16.sbn alias cvm41sccp.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/jar41sccp.8-3-4-16.sbn alias jar41sccp.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/apps41.8-3-4-16.sbn alias apps41.8-3-4-16.sbn
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/dsp42.8-3-4-16.sbn alias dsp42.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-3-4-16.sbn alias cvm42sccp.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-3-4-16.sbn alias cnu42.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/apps42.8-3-4-16.sbn alias apps42.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-3-4-16.sbn alias jar42sccp.8-3-4-16.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-3-5S.loads alias SCCP42.8-3-5S.loads
tftp-server flash:/phones/7902/CP7902080002SCCP060817A.sbin alias CP7902080002SCCP060817A.sbin
tftp-server flash:/phones/521_524/cp524g-08-01-13.bin alias cp524g-08-01-13.bin
tftp-server flash:/phones/7921/GUI-1.2.1.SBN alias GUI-1.2.1.SBN
tftp-server flash:/phones/7921/TNUX-1.2.1.SBN alias TNUX-1.2.1.SBN
tftp-server flash:/phones/7921/SYS-1.2.1.SBN alias SYS-1.2.1.SBN
tftp-server flash:/phones/7921/APPS-1.2.1.SBN alias APPS-1.2.1.SBN
tftp-server flash:/phones/7921/CP7921G-1.2.1.LOADS alias CP7921G-1.2.1.LOADS
tftp-server flash:/phones/7921/WLAN-1.2.1.SBN alias WLAN-1.2.1.SBN
tftp-server flash:/phones/7921/TNUXR-1.2.1.SBN alias TNUXR-1.2.1.SBN
tftp-server flash:/phones/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:/phones/7936/cmterm_7936.3-3-15-0.bin alias cmterm_7936.3-3-15-0.bin
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7931/cvm31sccp.8-3-4-16.sbn alias cvm31sccp.8-3-4-16.sbn
tftp-server flash:/phones/7931/apps31.8-3-4-16.sbn alias apps31.8-3-4-16.sbn
tftp-server flash:/phones/7931/cnu31.8-3-4-16.sbn alias cnu31.8-3-4-16.sbn
tftp-server flash:/phones/7931/jar31sccp.8-3-4-16.sbn alias jar31sccp.8-3-4-16.sbn
tftp-server flash:/phones/7931/dsp31.8-3-4-16.sbn alias dsp31.8-3-4-16.sbn
tftp-server flash:/phones/7931/SCCP31.8-3-5S.loads alias SCCP31.8-3-5S.loads
tftp-server flash:/phones/7975/cnu75.8-3-4-16.sbn alias cnu75.8-3-4-16.sbn
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7975/SCCP75.8-3-5S.loads alias SCCP75.8-3-5S.loads
tftp-server flash:/phones/7975/cvm75sccp.8-3-4-16.sbn alias cvm75sccp.8-3-4-16.sbn
tftp-server flash:/phones/7975/jar75sccp.8-3-4-16.sbn alias jar75sccp.8-3-4-16.sbn
tftp-server flash:/phones/7975/dsp75.8-3-4-16.sbn alias dsp75.8-3-4-16.sbn
tftp-server flash:/phones/7975/apps75.8-3-4-16.sbn alias apps75.8-3-4-16.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-3-4-16.sbn alias dsp45.8-3-4-16.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-3-4-16.sbn alias cnu45.8-3-4-16.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-3-4-16.sbn alias jar45sccp.8-3-4-16.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-3-5S.loads alias SCCP45.8-3-5S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7945_7965/cvm45sccp.8-3-4-16.sbn alias cvm45sccp.8-3-4-16.sbn
tftp-server flash:/phones/7945_7965/apps45.8-3-4-16.sbn alias apps45.8-3-4-16.sbn
tftp-server flash:/phones/7940_7960/P00308000500.sbn alias P00308000500.sbn
tftp-server flash:/phones/7940_7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:/phones/7940_7960/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/phones/7940_7960/P00308000500.loads alias P00308000500.loads
tftp-server flash:/phones/7937/apps37sccp.1-1-1-1.bin alias apps37sccp.1-1-1-1.bin
tftp-server flash:/phones/7925/GUIH-1.3.1.SBN alias GUIH-1.3.1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.1.SBN alias TNUXH-1.3.1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.1.LOADS alias CP7925G-1.3.1.LOADS
tftp-server flash:/phones/7925/APPSH-1.3.1.SBN alias APPSH-1.3.1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.1.SBN alias WLANH-1.3.1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.1.SBN alias SYSH-1.3.1.SBN
tftp-server flash:/phones/7916/B016-1-0-2.SBN alias B016-1-0-2.SBN
tftp-server flash:/phones/7915/B015-1-0-2.SBN alias B015-1-0-2.SBN
tftp-server flash:/phones/525/spa525g-7-1-3.bin alias spa525g-7-1-3.bin
tftp-server flash:/phones/3951/SIP3951.8-1-2.loads alias SIP3951.8-1-2.loads
tftp-server flash:/Desktops/CampusNight.png alias CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png alias CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png alias CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png alias Fountain.png
tftp-server flash:/Desktops/MorroRock.png alias MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png alias NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png alias TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png alias TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png alias TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png alias TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png alias TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png alias TN-NantucketFlowers.png
tftp-server flash:/Desktops/320x216x16/List.xml alias Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml alias Desktops/320x212x16/List.xml
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
connection plar opx 502
description Configured by CCA Operator
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name domestic
name international
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 500
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 501
b2bua
codec g711ulaw
no vad
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
corlist outgoing call-local
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]..[2-9]......
port 0/1/0
forward-digits 10
no sip-register
dial-peer voice 55 pots
corlist outgoing call-domestic
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/0
prefix 1
no sip-register
dial-peer voice 56 pots
corlist outgoing call-international
preference 5
destination-pattern 9011T
port 0/1/0
prefix 011
no sip-register
dial-peer voice 57 pots
description ** FXO pots dial-peer **-Emergency dial-peer
preference 5
destination-pattern 9911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 58 pots
preference 5
destination-pattern 911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 59 pots
preference 5
destination-pattern 9[2-9]11
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 60 pots
preference 5
port 0/1/1
forward-digits 10
no sip-register
dial-peer voice 61 pots
preference 5
port 0/1/1
prefix 1
no sip-register
dial-peer voice 62 pots
preference 5
port 0/1/1
prefix 011
no sip-register
dial-peer voice 63 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 64 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 65 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 66 pots
preference 5
port 0/1/2
forward-digits 10
no sip-register
dial-peer voice 67 pots
preference 5
port 0/1/2
prefix 1
no sip-register
dial-peer voice 68 pots
preference 5
port 0/1/2
prefix 011
no sip-register
dial-peer voice 69 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 70 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 71 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 72 pots
preference 5
port 0/1/3
forward-digits 10
no sip-register
dial-peer voice 73 pots
preference 5
port 0/1/3
prefix 1
no sip-register
dial-peer voice 74 pots
preference 5
port 0/1/3
prefix 011
no sip-register
dial-peer voice 75 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 76 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 77 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 2002 voip
description **AVT extension**
destination-pattern 555
b2bua
codec g711ulaw
no vad
dial-peer voice 2003 voip
description ** cue NIGHT auto attendant number **
destination-pattern 506
b2bua
codec g711ulaw
no vad
no dial-peer outbound status-check pots
telephony-service
video
load 7914 S00105000300
load 7915-12 B015-1-0-2
load 7915-24 B015-1-0-2
load 7916-12 B016-1-0-2
load 7916-24 B016-1-0-2
load 7902 CP7902080002SCCP060817A
load 7906 SCCP11.8-3-5S
load 7911 SCCP11.8-3-5S
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-3-5S
load 7936 cmterm_7936.3-3-15-0
load 7937 apps37sccp.1-1-1-1
load 7960-7940 P00308000500
load 7941 SCCP41.8-3-5S
load 7941GE SCCP41.8-3-5S
load 7942 SCCP42.8-3-5S
load 7945 SCCP45.8-3-5S
load 7961 SCCP41.8-3-5S
load 7961GE SCCP41.8-3-5S
load 7962 SCCP42.8-3-5S
load 7965 SCCP45.8-3-5S
load 7970 SCCP70.8-3-5S
load 7971 SCCP70.8-3-5S
load 7975 SCCP75.8-3-5S
load 521G-524G cp524g-08-01-13
load 525G spa525g-7-1-7
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Jeno's
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 6
voicemail 500
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service code *577
create cnf-files version-stamp 7960 Sep 04 2009 14:53:42
ephone-template  15
button-layout 7931 2
ephone-dn  2  dual-line
number 502 no-reg primary
label Main Line 1
description Main Line 1
name Main Line 1
preference 1 secondary 8
call-forward night-service 506
call-forward noan 501 timeout 20
huntstop channel
no huntstop
hold-alert 30 originator
night-service bell
ephone-dn  3  dual-line
label Main Line 2
description Main Line 2
name Main Line 2
preference 2 secondary 7
huntstop channel
no huntstop
ephone-dn  4  dual-line
number 104
label Courtesy Phone
description Courtesy Phone
name Courtesy Phone
call-forward noan 502 timeout 20
corlist incoming user-local
no huntstop
ephone-dn  5  dual-line
number 301 no-reg primary
label 301
description 301
name 301
ephone-dn  6  dual-line
number 302 no-reg primary
label 302
description 302
name 302
ephone-dn  7  dual-line
number 303 no-reg primary
label 303
description 303
name 303
ephone-dn  9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn  10  dual-line
number 106 no-reg both
label Steve x106
description Steve Horvath
name Steve Horvath
call-forward busy 500
call-forward noan 500 timeout 20
corlist incoming user-domestic
hold-alert 45 originator
night-service bell
ephone-dn  11  dual-line
number 100 no-reg both
label Greg
description Greg Bradley
name Greg Bradley
night-service bell
ephone-dn  12  dual-line
number 101 no-reg both
label Bay One
description Bay One
name Bay One
ephone-dn  13  dual-line
number 102 no-reg both
label Bay Two
description Bay Two
name Bay Two
ephone-dn  14  dual-line
number 103 no-reg both
label Bay Three
description Bay Three
name Bay Three
ephone-dn  20  dual-line
number 105
label Parts Room
description Parts Room
name Parts Room
no huntstop
ephone-dn  21  dual-line
label Main Line 3
description Main Line 3
name Main Line 3
preference 3
call-forward busy 501
call-forward noan 500 timeout 17
huntstop channel
ephone-dn  22
number 503
label Towing
description Towing
name Towing
call-forward all ##
ephone-dn  54
number 701 no-reg primary
park-slot
ephone-dn  55
number A801... no-reg primary
mwi off
ephone-dn  56
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address ****.****.****.****
max-calls-per-button 2
type anl
button  1:5
ephone  2
type anl
button  1:6
ephone  3
type anl
button  1:7
ephone  4
type anl
ephone  5
video
username "shorvath" password password
type 7941
button  1:10 2c2,3,21
ephone  6
video
max-calls-per-button 4
username "gbradley" password password
type 7921
button  1:11 2c2,3,21
ephone  7
video
username "bone" password password
type 7921
button  1:12
ephone  8
video
username "btwo" password password
type 7921
button  1:13 2c2,3,21 3:10
ephone  9
video
username "bthree" password password
type 7921
button  1:14
ephone  10
username "cphone" password password
type 521G
button  1:4
ephone  11
username "proom" password password
type 521G
button  1:20
ephone  12
type 7941
ephone  13
type 7941
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 5 100
ntp master
end
Message was edited by: Cindy Toy, Cisco Small Business Community Manager (not all of your post was showing so I updated this thread)
Steven Smith Tue, 09/15/2009 - 15:21
  • Gold, 750 points or more
Does this happen on every call, or only intermittently on this phone?
brandon.kallas Tue, 09/15/2009 - 15:28
The original phone did it on every call.   When it was replaced, the new phone was working correctly, but then about a week later it stopped working
Steven Smith Tue, 09/29/2009 - 07:42
Can you post the config as an attachment, the very long post cuts some of it off for me and is more difficult to read that way.
