Issue with HSRP on cisco 4506
Sep 10th, 2009
Need some help in an issue faced with HSRP running on a pair of redundant packet filter firewalls configured using 4506 switches.
The setup is L3 routed ports on these switches and configured to act as a firewall. The main issue that we see is even though the secondary 4506 ports are in standby state we see it passing packets out. Hence it is affecting the operation. Usually we have routes to destination from both 4506, because of this issue we have removed the route on the secondary.
Please let me know if there is any solution to this .
Jon Marshall Fri, 09/11/2009 - 01:55
Balaji
It's not entirely clear what your topology is.
You say the 4500's are connected via routed ports then you talk about HSRP. Could do a quick topology diagram with addressing so we can help you further.
Jon
