Cannot launch LMS after upgrade 3.1 -> 3.2
Sep 10th, 2009
I upgraded my LMS 3.1 (Solaris) to version 3.2 yesterday. But now I cannot launch it. Getting error HTTP Status 404 - /cwportal/c/portal/login.
I have try this:
"Shutdown Daemon Manager, then delete NMSROOT/MDC/tomcat/webapps/cwportal/db/portal.*. Then copy all files from NMSROOT/MDC/tomcat/webapps/cwportal/db/orig to NMSROOT/MDC/tomcat/webapps/cwportal/db. Verify that the casusers group has full control over the newly copied files. then restart Daemon Manager."
but I have always the same problem.
I have try from different browsers and clients, but I have always the same http notification.
Any idea?
Thanks a lot
Best Regards
Samuel
Joe Clarke Thu, 09/10/2009 - 20:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The upgrade may not have succeeded. Post a screenshot of the error, and the NMSROOT/MDC/tomcat/logs/stdout.log.
Joe Clarke Fri, 09/11/2009 - 09:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As I suspected, the portal installation is bad. Typically, in this case, it is best to uninstall LMS, then reinstall from scratch, then restore your LMS 3.1 backup (which was taken when you first upgraded to 3.2).
s.fasel Fri, 09/18/2009 - 04:03
I have reinstalled the LMS 3.1 and restored my LMS 3.1 backup. Now the portal is ok.
But I have an another problem with User Tracking. The devices connected on my Catalysts 2924XL (IOS 120-5.WC8) are not discover during major acquisitions. At the first major acquisition (just after the restoration), it was ok, but during the next acquisitions, no update.
Any idea ?
Thanks a lot
Sam
Joe Clarke Fri, 09/18/2009 - 08:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for the UT issue.
