Hardware Problems
Sep 11th, 2009
I try to install CCM6.1(2) in a HP DL380R05, with 4096MB RAM, 2'5GHZ DUAL and the system display what the hardware is uncompatible and i not install the CCM6.1(2).
Can you help me?
Overall Rating: 5 (1 ratings)
r.ferrero Fri, 09/11/2009 - 03:59
Thanks.
My server and my CCM 6.1(2) are compatible.
But I have the following problems:
- I have a HP DL380G5 with 142GB HDD, 4096MB RAM, 2,5GHZ dual processor.
- I introduce the disc of Call Manager 6.1(2) and pass the Hardware Test and I click continue to install the CCM.
- When the system begin to install de CCM, the server told me that the Hardware is not supported for this platform.
Help me please.
A greeting.
r.ferrero Fri, 09/11/2009 - 04:17
Sorry, it is 2,33MHz.
An all is correct with the matrix compatibility.
svuddanti Fri, 09/11/2009 - 05:19
HP DL380G5 Raid array controller shoud be Array P400 Controller with 256MB cache
ma.romero Fri, 09/11/2009 - 06:48
I want to install the following in two separate severs:
- CCM6.1(2) and the server display the errors:
- The hardware is not supported by the system
- IPCC 5.0(2)with OS 2003.1.2:
- BIOS version is P56-09/29/2008. the tested version is P56-12/28/2006, version RAID firmware is 5.22 and firmware support by this system is 2.08. Too, the CPU speed is not the expected 2333MHz, the actual speed is 2500MHz.
What have I do to install those software?
Thanks.
svuddanti Fri, 09/11/2009 - 06:55
What is raid controller name?
Configure disks to raid 1
ma.romero Fri, 09/11/2009 - 06:54
What do you mean with HP DL380G5 Raid array controller shoud be Array P400 Controller with 256MB cache ?
svuddanti Fri, 09/11/2009 - 06:57
You can't install software controller is not P400.
I faced same problem to install CCM 7.0
ma.romero Sun, 09/13/2009 - 12:00
OK.
Thanks for all.
I need to install the P400 controller into the server.
ma.romero Mon, 09/14/2009 - 08:06
I install a firmware of P400 Raid controller to versus 2.08, but i have a problems with the BIOS firmware P56-12/28/2006, when a install into the server, which not start and i have to restore the BIOS firmware again.
I don't know what to do more.
The Media Check of CCM 6.1(2) pass but when i start with the installation appear a message: the hardware is incompatible.
When I try to install Cisco OS 2003.1.2 the same that the Raul's message and me.
svuddanti Mon, 09/14/2009 - 22:16
Check CCM working hardware resources. This may help you
Processor Speed 2333
CPU Type Intel® Xeon (R) CPU 5140 @2.33GHz
Memory 4096 Mbytes
RAID Details
Smart Array P400 in Slot 1
Bus Interface: PCI
Raid 6 (ADG) Status: Disable
RAID 6 (ADG) Enabler Status: Enabled
Controller Status: OK
Chassis Slot:
Hardware Revision: Rev E
Firmware Version: 5.20
Cache Status: OK
Total Cache Size: 256 MB
Logical Drive: 1
Fault Tolerance: RAID 1+0
Status: OK
