ACS upgrade - 4.2 - Error with Backups etc
Sep 11th, 2009
Have recently upgrade a Cisco Secure ACS 4.0SW to 4.1.1.24 then onto 4.2 and pacthed to 9. This was on two servers that were both working fine except that we couldn't get the back up to work and also replication. Error messages were relating to "could open file etc" and also "backup,CSBacupRestore(OUT)export function exportUserSOC in DLL backupRestoreSupport.dll failed.
Can anyone help - i'm going to try a uninstall then clean.exe and then reinstall 4.2 again on the dr server while i wait for a response. Hopefully this work but i cannot locate what the problem is? cheers all John
gmarogi Thu, 09/17/2009 - 07:33
Explanation A failure occurred during the replication of an item of virtual interface configuration to one or more of the backup RPs.
Recommended Action The process will restart and attempt to recover from this error. If the message recurs, copy the error message exactly as it appears on the console or in the system log, call your Cisco technical support representative and provide the representative with the gathered information.
