Jon Marshall Fri, 09/11/2009 - 01:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
David
int fa1
ip nat inside
int eth1
ip nat outside
ip nat inside source static 10.87.140.1 192.168.56.1
Jon
trombidz1 Fri, 09/11/2009 - 03:07
the return of show ip nat translation is:
Pro Inside global Inside local Outside local Outside global
--- 192.168.56.1 10.87.140.1 --- ---
--- 192.168.56.2 10.87.140.2 --- ---
--- 192.168.56.3 10.87.140.3 --- ---
If I understand well :
on the FA 1 int , all packets signed with the source 10.87.140.1 goes in the router and leave it with the new source 192.168.56.1 when they go to 192.153.133.101
on the Eth 1 int, all packets to the destination 192.168.56.1 goes in the router and leave it with the new destination 10.87.140.1
Correct ?
excuse my english
regards
Jon Marshall Fri, 09/11/2009 - 03:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
David
"on the FA 1 int , all packets signed with the source 10.87.140.1 goes in the router and leave it with the new source 192.168.56.1 when they go to 192.153.133.101"
Correct as long as the destination IP is out the eth1 interface which it is.
"on the Eth 1 int, all packets to the destination 192.168.56.1 goes in the router and leave it with the new destination 10.87.140.1"
Correct again as long as the destination is out the fa1 interface which it is.
Jon
