aaa configuration
Answered Question
Sep 11th, 2009
I currently have an 1812 router setup to accept PPTP VPN connections. All authentication takes place against a RADIUS server (Microsoft IAS), the config for this, which is working fine, ias as follows:
IOS 124-24.T1.bin
aaa authentication ppp default group radius local
aaa authorization network default group radius
vpdn-group VPN
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Virtual-Template1
ip unnumbered Vlan1
peer default ip address dhcp
compress mppc
ppp encrypt mppe auto required
ppp authentication ms-chap-v2
ppp timeout idle 21600
radius-server host 1.1.1.1 auth-port 1645 acct-port 1646 key shared_key
I would like to be able to specify a backup RADIUS server, in case the primary failes. So I have specified the following config:
aaa group server radius authgroup
server 1.1.1.1
server 2.2.2.2
no radius-server host 1.1.1.1 auth-port 1645 acct-port 1646 key shared_key
aaa authentication ppp default group authgroup
aaa authorization network default group authgroup
However, with this configuration, authentication fails. A debug shows the following:
Sep 11 10:04:23.869: AAA/AUTHEN/PPP (00000056): Pick method list 'default'
Sep 11 10:12:18.889: %RADIUS-3-NOSERVERS: No Radius hosts configured or no valid server present in the server group authgroup
Correct Answer by Peter Paluch about 7 years 4 months ago
You must not deconfigure the "radius-server host" commands when grouping them under a server group. You must retain both the "radius-server host" commands and only subsequently sort them into the groups according to your liking.
Have a look at this example: I have created an example server group and referred to an undefined RADIUS server. Observe the warning displayed:
R1(config)#aaa group server radius Example
R1(config-sg-radius)#server 1.2.3.4
*Mar 1 04:49:00.446: %RADIUS-4-NOSERV: Warning: Server 1.2.3.4:1645,1646 is not defined.
So the solution in your case is simply to have both RADIUS servers defined before grouping in a server group.
Best regards,
Peter
Overall Rating: 5 (2 ratings)
Correct Answer
Peter Paluch Fri, 09/11/2009 - 05:49
Best regards,
Peter
bjssccouser Fri, 09/11/2009 - 06:32
Thanks for your comments. I've applied your suggestions and that looks to have resolved the issue.
Next time I'll enable console logging for all the config.
Thank you for your help on this.
