router not accepting login
Answered Question
Sep 11th, 2009
Hello, noobie here. I've just recently purchased a 3 routers and 3 switches. 2 of the routers I'm unable to get them to go through this;
R2(config-line)#login
Which should come up w/ this so I can assign a interface an IP address.
R2(config)#int s0
but it keeps staying in the
R2(config-lin)#
Please help, what else do you need?
Correct Answer by Richard Burts about 7 years 4 months ago
Steven
You are entering:
R2(config)#int s0
but the router does not go into interface mode (as is illustrated by Collin). The most likely cause of this is that your router does not have an interface serial0. Perhaps it is serial0/0 or something else. The easy way to know what interfaces the router has is to execute the command show ip interface brief (execute this from the command prompt - not from the config prompt).
Rick
Overall Rating: 5 (1 ratings)
Collin Clark Fri, 09/11/2009 - 06:54
It looks like your in the VTY lines. To enter into interface configuration, try something like this-
Router(config)#interface fastethernet0/0
Router(config-if)#ip address 192.168.1.1 255.255.255.0
Router(config-if)#no shutdown
Hope that helps.
Correct Answer
Richard Burts Fri, 09/11/2009 - 07:11
Steven
You are entering:
R2(config)#int s0
Rick
1thumper1 Fri, 09/11/2009 - 11:38
Excellent!
Yes, after more DD I believe it should be the serial 0/0, hopefully.
Thank you!
Regards.
1thumper1 Fri, 09/11/2009 - 13:45
Yes, the show ip interface brief gave me what I needed it was serial1/0, nothings ever easy.
Thx again!
Richard Burts Fri, 09/11/2009 - 14:03
Steven
I am glad that my suggestion helped you to find the solution to your problem. Thank you for using the rating system to indicate that your problem was solved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that there was a suggestion which did lead to a solution.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
