Store and Forward , Fax Detect problems...
Sep 11th, 2009
I cannot configure the Fax and store Dial peers and Fax detect. The connection schema has the following details:
1) First an external user dials the number 3987980 and receives a prompt
saying "If you want a voice call press "1" or press START to send a fax.
This call access to the system by an E1 connection in port 0/3/0:15
2) The destination extension is 2273 in a cisco 7911 phone and has the
respective user and and voicemail, if the external user dials 1? it sends
to the extension; if the final user is present answers the call and ends,
else if the final user is absent the call goes to the voicemail and ends.
3) If the external party press START in the fax machine, accepts the call
and translate the incoming fax into an email attachment and sends it to
[email protected] (The email server is with IP
I'm trying to configure that. I have the initial prompt, when press "1", it
redirects to the extension 2273 BUT when I press START in the remote fax
machine, it connects to the voicemail and records the fax tone and put it on
a voice message, NEVER translates it into an email attachment as data.
I'm supposing that when I press START in the Remote Fax Machine, it doesn't
have to ring in the final extension..but in my case is not like this.
Have I to deactivate de voicemail in fax calls?..or what have to do in the
Unity?. I'm very confussed about that.
!!!!First a translation rule for change the external number 3987980 to 2273
voice translation-rule 2
rule 1 /^3987980/ /2273/
!Create a profile for the translation rule
voice translation-profile PSTN
translate called 2
!!!!This is the application
package spanish
use paramspace spanish
service off_ramp_1 flash:app_faxmail_offramp.
service fax_det22 flash:app_fax_detect.
param fax-dtmf 2
param mode default-fax
param account-id-method gateway
param voice-dtmf 1
param prompt flash:/prompts/sp/
service on_ramp_1 flash:app_faxmail_onramp.
!!!First active the on_ramp_1 in a pots dial peer remember the call arrives
in E1 (port 0/3/0:15)
dial-peer voice 3987980 pots
service on_ramp_1
incoming called-number .
!Translation of 3987980 in 2273 (is it correct to be here???)
port 0/3/0:15
!Active the t37 store and fordward
dial-peer voice 370 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 3987980
information-type fax
session target mailto:[email protected]
!Active the fax detect (fax_det22) application
dial-peer voice 371 pots
service fax_det22
incoming called-number 3987980
!Translation of 3987980 in 2273 (is correct here???)
translation-profile incoming PSTN
!In configuration guide says "Configure at least one outbound VoIP dial peer
on the on-ramp gateway for voice messaging." the IP address of the
voice-mail server is not sure about this part
dial-peer voice 372 voip
!What destination use???
session target ipv4:
dtmf-relay h245-signal
fax rate disable
!This is another part i have doubts, in the guide says "Configure at least
one outbound dial peer on the on-ramp gateway for fax."...I don?t this correct????
dial-peer voice 375 voip
fax protocol t38
Could you please suggest me how to meet all these requirements and solve the
final application.
