Remote VPN issue
Sep 11th, 2009
in our network we created a remote VPN for remote access to our internal server through PIX 515E
currently i have created a group-policy with the name VPN300 and remote users are able to access but what happens they get full access to our internal
what i needd is restrict access based on the username with the local authentication since we are not using TACACUS or RADIUS
As per the document i have created a another group-policy and inthe group-policy attributes i mentioned as usename and password but its not working
kindly suggest
PIX Version 7.0(1)
interface Ethernet0
description WAN_connectivity
nameif outside
security-level 0
ip address XXXXX
interface Ethernet1
description Lan-connectivity
nameif inside
security-level 100
ip address
interface Ethernet2
description WEB_NATACCESS
nameif DMZ
security-level 80
ip address
access-list 110 extended permit ip
access-list accesstoTC1 extended permit ip
access-list accesstoALL extended permit ip
ip local pool RemoteVPNpool
ip local pool AccesstoTc1 mask
global (outside) 1 interface
nat (inside) 0 access-list 110
nat (inside) 1
nat (DMZ) 0 access-list 110
nat (DMZ) 1 access-list DMZtoInternet
route outside XXXXXXX 1
route DMZ 1
group-policy AccesstoTc1 internal
group-policy AccesstoTc1 attributes
user-authentication enable
group-policy vpn3000 internal
group-policy vpn3000 attributes
username admin2 password eY/fQXw7Ure8Qrz7 encrypted
crypto ipsec transform-set RVPN esp-des esp-md5-hmac
crypto ipsec transform-set RVPN1 esp-3des esp-md5-hmac
crypto dynamic-map DYN-map 1 set transform-set RVPN RVPN1
crypto map Remote-VPN 1 ipsec-isakmp dynamic DYN-map
crypto map Remote-VPN interface outside
isakmp identity address
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 11 authentication pre-share
isakmp policy 11 encryption 3des
isakmp policy 11 hash md5
isakmp policy 11 group 2
isakmp policy 11 lifetime 86400
isakmp policy 13 authentication pre-share
isakmp policy 13 encryption 3des
isakmp policy 13 hash md5
isakmp policy 13 group 1
isakmp policy 13 lifetime 86400
isakmp policy 15 authentication pre-share
isakmp policy 15 encryption 3des
isakmp policy 15 hash sha
isakmp policy 15 group 2
isakmp policy 15 lifetime 3600
telnet DMZ
telnet DMZ
telnet timeout 5
ssh timeout 5
console timeout 0
tunnel-group vpn3000 type ipsec-ra
tunnel-group vpn3000 general-attributes
address-pool RemoteVPNpool
default-group-policy vpn3000
tunnel-group vpn3000 ipsec-attributes
pre-shared-key *
tunnel-group AccesstoTc1 type ipsec-ra
tunnel-group AccesstoTc1 general-attributes
address-pool AccesstoTc1
default-group-policy AccesstoTc1
tunnel-group AccesstoTc1 ipsec-attributes
pre-shared-key *
vinoth.kumar Sat, 09/12/2009 - 00:10
Thanks its working
in my PIX config iam using the DMZ interface subnet as the Remote pool ip address which is coming under DMZ interface ip range
if i use the new subnet i need to make routing change so iam using range in the DMZ interface
whether it will be an issue or we can use the new subnet
