Unity Connection Voicebox without recording
Sep 11th, 2009
is it possible to attach a voicebox to a user without the record feature?
I want a voicebo only for playback a message and then disconnect the call.
Can someone describe the settings or a admin guide topic name where i can find the feature, if possible......
Thanks a lot
Christian
Brandon Buffin Fri, 09/11/2009 - 11:33
  • Purple, 4500 points or more
Christian,
A call handler should work for you. Go to Unity web admin > Call Handlers. Create a new call handler and set the After greeting action to "Send caller to" Hang Up. Record a greeting and give the call handler a DN.
Hope this helps.
Brandon
