Secondary Dial Tone
Sep 11th, 2009
My customer need to implement Voice Gateway that used to provide outside users to dial in different location. basically the user should call a PSTN Number then authenticated using caller ID. then giving a dial tone to dial the needed number.
the implemented GW is 2821-v\K9
Is there any solution to provide this.
Best Regard,
Abbas
CHRIS CHARLEBOIS Fri, 09/11/2009 - 12:21
  • Silver, 250 points or more
With CallManager 6.x or higher, you could acomplish that with Mobility. It's fairly basic, in concept, and I believe that a TCL script could do it, too.
