Can't start WCS 6.0.132.0 after upgrade
PeterJacobsen
I've just upgraded WCS from 4.2.128.0 to 6.0.132.0 But WCS won't start. The hm_launchout.txt file show:
Starting Health Monitor as a primary
Checking for port 8082 availability… ok
Starting Health Monitor Web Server…
Health Monitor Web Server Started.
Starting Health Monitor Server…
Health Monitor Server Started.
Starting WCS server
Invalid maximum heap size: -xmxm
Could not create the Java virtual machine.
Anyone knows what to do?
Lucien Avramov
Level 10
Level 10
You hit bug : CSCta18874
To fix it:
Edit startServer.sh in WCSx.x/bin folder or startServer.bat in Windows
Replace a line with:
export JAVA_OPTS="-server -Xms256m -Xmx1024m -XX:MaxPermSize=256m -Djava.awt.hea dless=true"
This should fix your problem
9 Replies 9
Lucien Avramov
Level 10
Level 10
To fix it:
Thank you so much.
It was exactly that bug.
Even though my installation isn't German I did the workaround:
Modify WCS_Install_Directory\bin\startServer.bat
change the line:
set MAX_HEAP_SIZE=m
to
set MAX_HEAP_SIZE=1024m
I had the same problem with a server installed with a the danish locale. (I guess the same as Peter's)
Yes my was also Danish.
Did the workaround solved you issues?
Peter
Yes
This happens on upgrades regardless of the language.
I will modify the release notes of the bug.
Thanks for reporting the issue and glad to hear the workaround fixed the issue.
suporteziva
lavramov,
Thank you soo much for this reply!
It's save me!
Yes I did.
Just change
set MAX_HEAP_SIZE=m
to
And WCS starts up.
Glad to help. Dont hesitate to vote for this. The more votes on this post, the more chances people will look into it if they run in the issue.
