No VPN traffic: please help me!!
Sep 12th, 2009
hi
I have set u a VPN L2L between my HO and a branch, the tunnel is establised (as you can see at the end of the configurations) but no traffic can flow through (am not able to ping)
my configurations are attached.
habibnoubissi Sun, 09/13/2009 - 23:15
Please I want to know what should be the next hop of my default route in Branch config? the wan address of router of the HO?
Please I am xaiting for your answer
this is the configuration of HO
crypto ipsec transform-set vpn esp-3des
crypto map vpnregeo 30 ipsec-isakmp
description Tunnel-to-Residence
set peer XXXXXX
match address 170
i cant see the transfor -set add to crypto map vpnregeo 30 you need add the next line:
set transform-set vpn
