Problems Loading new ATA firmware
Sep 12th, 2009
I have a CUCM Version 7.0.2
In the Device Defaults I had ATA030203SCCP051201A for Cisco ATA 186.
I loaded ATA030100SCCP040211A.zup into CCM.
In the device phone I changed the "Phone Load Name" to ATA030100SCCP040211A or ATA030100SCCP040211A.zup, saved and reset the device, but the ATA cannot get this new firmware.
I am doing something wrong? Am I missing something?
Best Regards.
Elio Fernandes
Rob Huffman Sat, 09/12/2009 - 08:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Elio,
Please note the ATA filetype required for CUCM 7.x***
Depending on which version of Cisco Unified Communications Manager you are running, download the following:
•***For Cisco Unified CallManager release 5.1 and later, you need:
cmterm-ata-sccp.3-2-4.cop.sgn
•For Cisco Unified CallManager releases 4.1, 4.2, and 4.3, you need:
ata_03_02_04_sccp_090202_a.zip
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/3_2_4/english/release/notes/atarn324.html
Hope this helps!
Rob
efernandes67 Sat, 09/12/2009 - 10:51
Hi Rob,
Thanks for your help.
Rob, the real problem is that the ATA works fine with the defaul firmware, but when it does not work in SRST mode! This is why I tried to use an older firmware. I have 2 cases with a C1760 (Call-manager fallback v3.0) and a C2800(Call-manager fallback v3.3). Can I give me anhother help to make ATA work in SRST mode?
Best Regards,
Elio Fernandes
