SPA8800 Firmware - Bridge/Switch mode
My SPA8800 has firmware 6.1.7 (GW). The Quick Start Guide lists an IVR Action # 201 for setting the device mode for Router/NAT or Bridge/Switch. The IVR however reports this option to be invalid. Web interface does not have the option either. I would like to use the Bridge/Switch mode. Will this require a firmware update or have I missed something configuration wise ? Where do I find the required firmware update ?
Alberto Montilla Mon, 09/14/2009 - 07:16
  • Cisco Employee,
Dear Sir;
SPA8800 is a client device. The LAN port cannot be used other than for Admin purposes, and it is set in NAT mode (should not be changed). I will ask the documentation team to have a look and potentially correct the document to remove this option from the documentation.
Thanks for highlighting this issue and helping us to make better products.
Alberto
Related Content
