SPA 3102 outgoing voip call got cut off as soon as it's picked up
Sep 12th, 2009
I successfully registered SPA 3102 with my ITSP. All the in-coming calls work perfectly but when I tried to make calls via Voip, all calls got cut off as soon as people picked them up. On my call list, I can see lots of calls that have 1 second long conversation.
Can anyone help me out?
Patrick Born Mon, 09/14/2009 - 14:01
  • Cisco Employee,
Hi nsgsgcisco,
Please provide:
the 3102's config
syslog log [enable level 3 debug first]
Once you've got the syslog running, make 3 outbound calls and then stop the syslog. Hopefully the syslog log will give us an idea of what the issue is.
Patrick
nsgsgcisco Tue, 09/15/2009 - 09:04
Hi Patrick
Thanks for your reply.
I have fixed the problem. It was due to the wrong Codec chosen. As what my ITSP suggested, I am using G729 as my prefered Codec now.
Ming
Patrick Born Tue, 09/15/2009 - 16:06
  • Cisco Employee,
Thanks for following up Ming.
Patrick
