PBR and NAT on Same Interface
Sep 13th, 2009
I have a PBR and NAT configuration in one of the core switch interfaces as follows:
interface Vlan22
ip address 172.24.22.251 255.255.255.0
standby 22 ip 172.22.254
standby 22 priority 110
standby 22 preempt
ip policy route-map PROXY
ip nat inside
interface gig 3/48
ip address 192.168.1.100 255.255.255.0
ip nat outside
IP access-list extended PROXY
permit tcp host 172.24.22.25 any eq 80
permit tcp host 172.24.22.25 any eq 443
route-map PROXY permit 10
match ip address PROXY
set ip next-hop 192.168.1.1
ip nat inside source list PROXY interface G3/48 overload
What I am trying to do here is to direct the users on any VLAN to the Proxy inside VLAN (VLAN 22), and then direct the proxy traffic to a dedicated internet link that is connected to the core switch, however a NAT rule needs to be applied first so that the internet modem sees the Proxy with a specific IP address.
I need to make sure whether the above configuration is workable and to understand what who takes privilege over the other PBR or NAT.
Appreciate your feedback.
Haitham
Jon Marshall Sun, 09/13/2009 - 03:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Haitham
"What I am trying to do here is to direct the users on any VLAN to the Proxy inside VLAN (VLAN 22),"
presumably the config for this is not included in your post ?
"and then direct the proxy traffic to a dedicated internet link that is connected to the core switch, however a NAT rule needs to be applied first so that the internet modem sees the Proxy with a specific IP address"
this should work fine. PBR is done before NAT so the traffic will be routed out of the gi3/48 interface and then source Natted to 192.168.1.100. See this link for order of operations on a Cisco router -
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
Jon
