Migrate some information from a CUCM 4.1 to 6.1
Sep 13th, 2009
can i mgrate the following from a existing CUCM 4.1 cluster to existing CUCM 6.1 :
- Personnal adress book
- Forwad configuration of IP Phones (noan, busy)
- some translation that permit to call without entering the complete phone number but just 4 digits for example.
Mohamed
Rob Huffman Sun, 09/13/2009 - 07:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi again Mohamed,
You can use the BAT Export from CUCM 4.x and then Import on CCM 6.x but the .csv files will need to be tweaked. The look and feel of BAT on 6.x versions is a little different so you would have to experiment with what fields need to change before the actual Import is done. This can be used to migrate the Device FNA/Busy info. PAB and Translation rules will need to be re-configured :)
Cisco Unified Communications Manager Bulk Administration Guide
Inserting Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/7_0_1/t03inph.html
Hope this helps!
Rob
