Reflexive ACL behaviour
Sep 13th, 2009
Hi friends,
A basic doubt.
I am checking REFLEXIVE ACLs. During Lab i found this behaviour.
152.50.12.1 (R1)-----(R2) 150.50.7.7
where 150.50.12.1 is untrusted & 150.50.7.7 is trusted.
Reflexive ACLs are configured and working perfectly as expected. When I
initiated ICMP ping from 150.50.7.7 it is creating Reflexive ACL in R2 as
below:
permit icmp host 150.50.12.1 host 150.50.7.7 (10 matches) (time left 76)
I thought after this temperory ACL creation, I should be able to ping from
150.50.12.1 to 150.50.7.7. But it failed to ping even though I am able to
ping 150.50.12.1 from 150.50.7.7
Is this a normal behaviour?
Thanks for valuable answers
sairam
Overall Rating: 5 (2 ratings)
Peter Paluch Sun, 09/13/2009 - 10:49
Hi Sairam,
It depends on how you set up both the pair of ACLs. Can you post the configuration of the router that contains the reflexive ACL?
Best regards,
Peter
snarayanaraju Sun, 09/13/2009 - 11:47
Hi Peter,
Configuration is done on R2
ip access-list TRUSTED-UNTRUSTED
permit ip any any reflect SAIRAM
ip access-list UNTRUSTED-TRUSTED
evaluate SAIRAM
interface ser 0/0
des #### UNTRUSTED #####
ip access-group UNTRUSTED-TRUSTED in
interface fa 0/0
des ##### TRUSTED #####
ip access-group TRUSTED-UNTRUSTED in
Peter, this is the snapshot of the configuration made on R2
Hope this is sufficient to help me
Sairam
Peter Paluch Sun, 09/13/2009 - 12:37
Hello Sairam,
Your config is OK. I believe that the reason that it does not work lies in the fact that despite the "show access-list" command shows only the hosts and protocol in your reflexive ACL, internally the reflexive ACL holds more information about how the return packet should look like. I suspect that for ICMP, when you ping from inside to outside, the reflexive ACL will match for an ICMP echo-reply message. This would also explain why pinging from outside to inside does not work: the packets are of the type ICMP echo, not echo-request as the reflexive ACL entry expects.
Maybe you should try testing this with a real equipment and some packet generator that is able to generate a packet from an arbitrary port - the "netcat" utility for Linux can be used for that. I suggest using UDP packets as they have no state information in their header.
Best regards,
Peter
