VPN failure?
Sep 13th, 2009
folks
i'm having a strange issue
i have a number of remote users running a recent version of the cisco vpn client
they connect over a dedicated ISP cloud to an ASA cluster 5540 running IOS 8.0.4
the remote users are using a netgear modem to connect to a broadband line and each modem, after being authenticated is allocated a static IP from an ACS 1113 SE on a dmz
once the VPN is established the ASA passes down a profile with an IP, proxy, DNS etc
my problem
some users are losing the IP connection even though the VPN client still shows the VPN is up, i.e. the padlock on the client software is up but they can't ping anything
if i run wireshark on my PC on the corporate lan i can see the remote users ping to my PC and i can see the reply
outbound on the ASA 5540 before it goes in the VPN tunnel
i've tested a client and when the connection dies the VPN padlock is still up but wireshark, on the client doesn't see an icmp reply
strangely an ipconfig on the remote client shows the client IP but a different address, on the same subnet, as the gateway
i suspect this may be causing routing problems but i can't see anything because of the encryption
anyone seen this type of behaviour before or have an suggestions on how to troubleshoot it?
thanks to anyone taking the time to read this or reply and my apologies for the overly detailed post
ggilbert Tue, 09/15/2009 - 06:26
  • Cisco Employee,
I read through your problem description and have some queries.
a. When do a ipconfig on the remote client, you said the IP address is different? What do you mean by that?
When you did a wireshark capture, you saw the packet coming from an IP address that is different from the client IP address assigned on the Virtual Adapter?
b. sh cry ipsec sa peer x.x.x.x
When you issue that command, do you see packets getting encrypted increment with the return packet sent to the ASA.
Can you please confirm that.
Gilbert
mulhollandm Thu, 09/17/2009 - 00:34
gilbert
many thanks for your reply
a. the results of the ip config were showing one address for the vpn adapter, i.e. 172.16.50.45 but the gateway was slightly different, i.e. 172.16.50.99
unfortunately this looks like a red herring as some of those having connectivity issues have the same ip for both the adapter and the gateway
the capture taken on the pc in the lan saw ping requests coming from the remote client with the vpn adapter address and the replies were sent back
i can see the reply as far as the asa were the vpn ternminates
b. have got a user with problems during the day yet but i will try this command
many thanks for youe time and efforts
