SPA922 IP Phone one way call problem
Sep 13th, 2009
Hi, we have a few types of IP phones deployed in the field.  Currently we're experiencing a problem with a Planet VIP-103PT phone calling a Cisco SPA922 phone:
  • When a Planet VIP-103PT initiate a call to a Cisco SPA922 (firmware 6.1.5a), upon answering, no voice can be heard on both ends.
  • But the other way around, a Cisco SPA922 calling a Planet VIP-103PT, everything works normally.
Any idea what the problem might be?  Thanks!
Alberto Montilla Mon, 09/14/2009 - 07:25
Dear Sir;
This may have to two with two things (provided there are no nat issues):
- Packetization time is not matching
- Codec naming issues.
I suggest you check and the traces and ensure that codec and packetization time configuration is the same for both phones.
martinkong Thu, 09/17/2009 - 01:41
Thanks for the suggestion.  As it turned out, it's a bug in the Planet phone's firmware.  After installing their beta firmware, the problem is solved.
