7921 IPPhone is not showing signal strength
Sep 13th, 2009
I am having AP 1131, with SSID - cisco vlan 31 and SSID -voice vlan 103, in my laptop I am able to see cisco ssid but not voice ssid, please light me what I am missing.
I have brand new 7921 IPPhone, in that I configur SSID as voice and cisco, but it says registration fails, in 7921 antenna I am not able to see any signal strength..
Please help us to solve this problem
migilles Mon, 09/14/2009 - 12:16
  • Cisco Employee,
No clients can associate to the voice ssid?
If so, if this is autonomous, then you need to add the ssid under the appropriate interfaces.
Then on the 7921 side, ensure you configure the 802.11 mode and security to match.
If you enter site survey mode, it should show the ap there if it responding to probe requests.
Please attach your AP config in order to get further assistance.
BALAMURUGAN SINGARAM Mon, 09/14/2009 - 20:35
The below is the SH run config of my access point:
RCA-BahwanIT#sh run
Building configuration...
Current configuration : 2182 bytes
version 12.4
no service pad
service password-encryption
hostname RCA-BahwanIT
enable secret 5 $1$rCvL$/cBIHnneTcrz1OmcMYPe9.
no aaa new-model
dot11 ssid voice
vlan 103
authentication open
guest-mode
dot11 network-map
dot11 arp-cache optional
power inline negotiation prestandard source
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid voice
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.103
encapsulation dot1Q 103
no ip route-cache
bridge-group 103
bridge-group 103 subscriber-loop-control
bridge-group 103 block-unknown-source
no bridge-group 103 source-learning
no bridge-group 103 unicast-flooding
bridge-group 103 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid voice
no dfs band block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.103
no ip route-cache
bridge-group 103
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.103
ip helper-address 142.3.64.11
no ip route-cache
bridge-group 103
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
RCA-BahwanIT#
I have vlan 103, in switch vlan 103 is voice vlan, when I try laptop wirless, I am able see the voice network and related DHCP I am able to get. But in 7921 IPPhone is not get register.
In 7921 site survery it shows ch. AP name RSSI
as 01 [hostname] RSSI -27.
In profile1 [WLAN configuration] as follows:
SSID - voice
security mode - open
802.1 mode - auto-RSSI
Please light me what Iam missing to get regiaster IPPhonhe 7921.
migilles Wed, 09/16/2009 - 12:33
  • Cisco Employee,
The config looks good.
You are using open authentication without encryption, so ensure the security mode is set to Open.
Check the nework settings to see if the phone is getting a DHCP address.
Ensure the phone has at least 1.3(2) firmware loaded.
BALAMURUGAN SINGARAM Wed, 09/16/2009 - 21:37
In 7921, The security mode is - open; 802.11 mode - auto-RSSI, call power save mode - u-apsd/PS-Poll.
DHCP Enabled - Yes.
But the 7921 is not get register with AP.
7921 Model Information as follows:
App LoadID CP7921G-MFG-C.2LOADS
Please light me what I am missing in IPPhone side.
migilles Wed, 09/23/2009 - 11:24
  • Cisco Employee,
So is not getting an IP address...correct?
If not, ensure the AP switchport is set for trunnking mode and that VLAN is allowed on the uplinks.
Otherwise you can do a simple test and put the voice ssid into VLAN 1 temporarily to try, where then the switch will tag the packets.
bbxie Wed, 09/23/2009 - 22:39
  • Silver, 250 points or more
If using the Cisco Unified Wireless IP Phone 7921G World (-W) model, then you must enable 802.11d, for example if you are in US, then need:
Interface dot11radio X
world-mode dot11d country US both
