09-13-2009 11:34 PM - edited 03-15-2019 07:43 PM
Hi all,
Can I use the following destination-pattern 10 When I dial 108888 to remote site ?
dial-peer voice 10 voip
session target ipv4:172.29.219.1
Man
Solved! Go to Solution.
09-14-2009 03:33 AM
No, you have to extend your destination-pattern information.
One way could be to use: destination-pattern 10.... if you have fixed number of digits or 10T if there is more digits to come.
I would recommend to read whole document: http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html#wp1067900 + find information about wildcards used by dial-peers.
rate if this help
09-14-2009 03:33 AM
rate if this help
09-14-2009 05:30 PM
Hi KonradStepniewski
Thanks for your helpful information
Leung Che Man
