Network Infrastructure to DMVPN
Sep 14th, 2009
Hello Folks!!.
I want to mount a DMVPN infraestructure. I have three remote networks and my central site. I have some cisco routers, the models are 850 series and I have thinked use it like spoke. The problem is that I don't know what is the router model to use like hub device.
Could somebody to help me, please?.
Thanks in Advance!!.
Greetings!.
elias.manchon Mon, 09/14/2009 - 23:28
Hi Giuseppe,
Thanks by your response. Other Question, with this family router I can to use HSRP to failover?.
Thanks.
Giuseppe Larosa Tue, 09/15/2009 - 02:04
Hello Elias,
yes HSRP is supported in this family.
I guess you would like to use the HSRP VIP as endpoint for IPSec or GRE.
this should be possible too.
Hope to help
Giuseppe
