CiscoWorks
Sep 14th, 2009
Good evening,
I'm finding information about CiscoWorks, is a modular software?
For example I can install only a tool (or utility) of the suite, or I must install all the suite?
I've another question what are the condition of licensing?
Best Regards
Davide Sacca'
Marvin Rhoads Mon, 09/14/2009 - 05:46
CiscoWorks LAN Management Solution (LMS) is sold as a bundled suite of applications. That bundle includes:
Common Services
CiscoWorks Assistant
LMS Portal
Resource Manager Essentials (RME)
Campus Manager
CiscoView
Internetwork Performance Monitor (IPM)
Device Fault Manager (DFM)
Health and Utilization Monitor (HUM) - trial version only - additional license required for full version.
The first three applications listed are installed by default. You may choose any or all of the remaining ones to be installed based on your needs.
Reference: http://www.cisco.com/en/US/customer/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/overview.html
yjdabear Mon, 09/14/2009 - 05:48
CiscoWorks has become an umbrella brand nowadays. There're several distinctive product suites sold under that name:
http://www.cisco.com/go/ciscoworks
Assuming you're referring to CiscoWorks LMS, here're the options you'd be presented with when installing LMS 3.x:
1) Common Services 3.x
2) LMS Portal 1.x
3) CiscoWorks Assistant 1.x
4) CiscoView 6.x
5) Integration Utility 1.x
6) Resource Manager Essentials 4.x
7) Campus Manager 5.x
8) Device Fault Manager HPOV-NetView adapters 3.x
9) Device Fault Manager 3.x
10) Internetwork Performance Monitor 4.x
11) All of the above
---Add-On Applications--------------------------------
12) Health and Utilization Monitor 1.x
So it definitely qualified for the "modular" descriptive.
I don't think LMS 2.x is being sold anymore, so here're the LMS 3.x licensing options in Table 2 or 3:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/product_bulletin_c25-534875.html
