VPN cluster
Sep 14th, 2009
Dear Sir,
I have the following items
1) 2 x ASA5520-K9
2) 10 SSL VPN license
I want to set up a VPN cluster to provide at least 10 SSL VPN connections.
Question:
1. Do I need to setup HA before configuring VPN cluster?
2. Will the solution support 10+2=12 concurrent SSL VPN connections?
Thanks.
robw20009 Wed, 09/16/2009 - 07:53
Are you tring to configure your ASA 5520s in an Active/Active configuration? If so VPN functionality will be disabled. They must be set to Active/Passive.
