Resetting Excluded Clients
Sep 14th, 2009
Hi All,
I'm afraid I may well be asking something that is fairly simply, the question is how do you reset excluded clients, the WLAN creation page (on WCS 6.0 at least) says in note 2 "....will require administrative override to reset excluded clients", but I have not been able to find anything in the on line help or on the Cisco Site.
As ever, any help will be welcome.
Overall Rating: 3 (1 ratings)
Leo Laohoo Mon, 09/14/2009 - 15:21
On the main menu to the left, click on the "excluded clients". You'll find a list of excluded clients and on the right, there's a blue drop down link. Hover the mouse on it and choose Remove.
Hope this helps.
scottwilliamson Tue, 09/15/2009 - 00:00
Hi Leo,
Thanks but that must be for an earlier version - I'm running WCS6.0.
scottwilliamson Tue, 09/15/2009 - 00:25
Found it!
from the on line help......
"Monitor Client > > Select a Command
The Select a command functions can be accessed from the Client Details window.
You can access client details from the Monitor > Clients window in the following ways:
Perform a client search using the applicable search parameters. For more information on performing a client search, see "Monitoring Client Details." -OR-
Click the applicable client from the User Name column.
From the Select a command drop-down menu, the following actions can be performed:
Running a Client Link Test
Receiving Radio Measurements for a Client
Viewing Client V5 Statistics
Note This selection is only available for CCX v5 and higher clients.
Disabling a Current Client
Removing a Current Client
Enabling Mirror Mode
Viewing a Map (High Resolution) of a Client's Recent Location
Viewing a Map (High Resolution) of a Client's Current Location
Viewing an Access Point Association History Graph
Viewing an Access Point Association History Table
Viewing a Roam Reason Report for the Client
Viewing Detecting Access Point Details
Viewing Client Location History
Viewing Voice Metrics for a Client
Troubleshooting a Client"
Trending Topics - Security & Network
