CSM - Daemon manager problem
Sep 14th, 2009
Hi:
I can not start "Cisco Security Manager Daemon Manager" service.
In the syslog.log file I have the next error:
Sep 14 14:19:39 127.0.0.1 100: <28> dmgt[3148]: 2507(W):Daemon manager anonymous user has not been set up: 00000569
brispin Fri, 09/18/2009 - 14:18
check the following:
1- Check if the casuser is the group member of local admin?(For windows)
2- Any Terminal Services are in used or not.
3- I want you to reset your casuser by doing CSCOpx\setup\support\resetCasuser.exe
4- Stop and restart the daemons by
"net stop crmdmgtd". Wait for few minutes. Then "net start crmdmgtd" from the command
line. (If Windows)
"/etc/init.d/dmgtd start". Wait for few minutes and do "stop" instead of start.
(If Solaris)
