SSH for Tacacs+
I have an early Version Tacacs+ - CSACS3.2-WIN-K9
we have upgraded all our cisco devices to ssh 1.5/ ssh 2 however when we renew passwords the tacacs server is not allowing password changes . way around this is to use a telent to a device that currently is not ssh login but this is not a long term solution
Does anyone know how to make tacacs+ allow password changes when we have logged into a device using ssh ?
Thanks !!
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Mon, 09/14/2009 - 08:30
  • Red, 2250 points or more
Password expired notification doesn't work with any version of SSH. However,
password change is supported by SSHv2. SSHv1 doesn't support the necessary
message types to initiate a password change sequence. Only the very latest
versions of IOS code on the routers/switch support SSHv2.
There are couple known bugs filed to address this issue on IOS,
CSCdy54970: Tacacs+ ACS password change with SSH
1st Found-In: 12.2M
Fixed-In:
12.1(22)EA3
12.2(18)SXE
12.2(25)S6
12.2(25)SEA
12.2(25)SEB
12.2(27.7)S
12.3(10.1)T
CSCin91851: Support keyboard-interactive authentication method
Fixed-In:
12.4(10.1)T
12.2(33)SXI
12.4(17.9)M
12.2(32.8.11)SX142
12.2(33.1.10)SXH
12.4(13f)M
12.2(33)SXH2
12.2(32.8.11)XJC153.1
12.2(32.8.1)YCA172.24
12.4(22.3.4)PIC1
Link to check the bug information
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
~JG
Do rate helpful posts
cisco24x7 Tue, 09/15/2009 - 13:04
  • Silver, 250 points or more
JG,
You're a funny person, posting CSCdy54970 that can be accessed by internal Cisco Employees.
Some clarifications:
"Password expired notification doesn't work with any version of SSH"
This is FALSE, if I understand correctly. See below:
[[email protected]-firemon ~]# ssh -l test 172.20.20.20
Password:
Your password will expire in 1 more logins
c2811>sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 15:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
c2811 uptime is 3 weeks, 5 days, 3 hours, 36 minutes
System returned to ROM by reload at 17:24:56 UTC Thu Aug 20 2009
System image file is "flash:c2800nm-adventerprisek9-mz.124-24.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID FTX1152A3RZ
2 FastEthernet interfaces
1 Serial interface
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
c2811>
Can you post the content of that bug ID CSCdy54970 report here?
A follow-up question: Do you know if password change via ssh work with s72033-entservicesk9_wan-mz.122-18.SXF14.bin?
Thanks in advance.
